Signal Conditioning
SCC AI04 vs SCC AI14 (10khz and 4hz)
Hello everyone,
I am in the process of starting a setup with an SC-2350.  One question I have so far is regarding the difference between the two AI SCC modules for +- 5V.  The AI04 has a bandwidth spec of 10Khz and the AI14 has a bandwidth spec of 4hz.  I am a little confused as to how this spec is being used. If I understand this correctly as long as my signal is not expected to change more than 4 times a second then the AI14 would give me a cleaner signal but if I am expecting to see large signal changes faster than 4 times a second then the AI04 would be the proper choice.  This bandwidth spec refers to the built in filter correct?  And should I really only be concerned with it if I am looking at an AC signal (sine wave).  I will be using these modules to measure an LVDT, and for all intensive purposes I will be measureing a DC signal that will change relativly slow (0.01mm/sec or ~0.248Vdc/sec) so does this bandwidth spec not really apply to me?  I would be more than happy if someone could set me straight on this topic or point me in the proper direction.
Thank You,
Steve
(3,356 Views)
Hi Steve,
You are right. The bandwidth specification is essentially a low-pass filter. It sounds like your application may be able to get away with the lower cutoff frequency of 4Hz. This would give you a cleaner signal in the end as it would cut out any higher frequency noise.
Cheers,
Garrett H
(3,340 Views)
