Signal Conditioning
SCC-FT01/SC-2345 issue
Hi all,
I have a hardware issue and am quite a novice with this sort of thing so I was hoping someone might have an idea with the limited info I am able to provide. I am acquiring displacement data from two rotary potentiometers via an SCC-FT01 coupled to an SC-2345. Yesterday I hooked up a rotary potentiometer that had apparently blown and immediately noticed the inductor labeled L1 on the board was red hot. I detached the pot and have since tried to use another that is known to be good. In the first input location I get a raw reading of approximately zero volts when I plug the pot in (-5 V when none is attached), while in the second it performs flawlessly.
The green wire from the board is attached to input 6 on the module, while 2 black wires marked com are input into terminal 4 and two red wires labeled +5 V are input into terminal 1. On the interior, the wire from I/O pad 1 is attached to signal connection pad 6 under "all," while the wire from I/O pad 4 is attached to signal connection pad 3 under "all." This wire is also jumped to I/O pad 5 on the backside of the circuit board.
I have swapped this module for one wired and jumped identically to no avail so I suspect that the problem may be within the board but have been able to find no information that seems to address this issue.
Thanks in advance for any help and suggestions.
(3,252 Views)
I noticed that there were two posts on this issue, so I wanted to link them together: http://forums.ni.com/ni/board/message?board.id=250&message.id=22304&jump=true
Hal L.
(3,244 Views)
