Signal Conditioning
SCC FT01 wiring assistance
I am seeking assistance with wiring the SCC FT01 feed-through module with a SC 2345 to measure pressure changes.
Which pin on the feed-through module accepts the connection with the analog input of the shaft encoder?
If you require more details, I'd be happy to provide them.  Thanks in advance for the help!
-Carolyn 🙂
(4,982 Views)
Hello, you can look at the information that you are seeking in these links
https://www.ni.com/docs/en-US/bundle/371075b/resource/371075b.pdf
https://www.ni.com/docs/en-US/bundle/373743d/resource/373743d.pdf
There you can find the device's manuals and see how the wiring should be done.
I hope this helps!
(4,963 Views)
