Signal Conditioning
SCXI 1100 Two Point Calibration
I am using a SCXI 1001 chasis with an SCXI 1120 module configured through an SCXI 1100 to a PCIe-6321 device.
I have recently upgraded my computer from Windows 98 to Windows XP and my LabVIEW software from LabVIEW 4 to LabVIEW 2009. We previously had some custom code that would assist our tech's in performing a two-point calibration on the SCXI 1100 module. When I try to run this code I get an error 10401 regarding AI Group Config.
What I really need to do is set my grounds (that's what the custom code used to do). Is there an easy way to do this with LabVIEW 2009 such that I do not have to re-write the custom calibration sub-routine (for grounding my devices).
Note: I am a new user.
Thanks in advance,
Showleh
(5,893 Views)
Hi Showleh,
What version of the NI-DAQmx driver are you using? You can find this information under the My System Tree > Software.
Also, I have attached a document which explains how to remove the initial offset for load or strain measurements with an SCXI-1520:
http://digital.ni.com/public.nsf/allkb/DA2ABCFA3D4C73FD862571080008B8B1
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(5,881 Views)
