Signal Conditioning
SCXI-1112 aquires < 1Hz other SCXI and PXI devices OK
SCXI-1112 aquires slow, < 1Hz. I have an SCXI-1160, PXI-6602 and PXI-6052E in the same Chassis and they aquire > 100 Hz.
(2,951 Views)
Nardelli,
Could you provide some additional details concerning your setup? The SCXI-1112 has a maximum sampling rate of 333 kS/s. Thus, most likely, the program that is controlling the hardware is determining the sampling rate. Which development environment are you using? What type of programming structure are you implementing with regards to the SCXI-1112? Single-point acquisition (software timed)? Buffered acquisition (hardware timed)?
Spencer S.
(2,951 Views)
