Signal Conditioning
SCXI 1126
Bonjour,
quelqu'un connait la résolution de la carte SCXI 1126, il n'y a pas d'info dans la doc.pdf, ni dans les ressources.
merci d'avance
Philippe.
Philippe B.
Certified Associate Developer / Dépt Moyens d'essais
www.ingenia-system.com
(6,557 Views)
Hi Philou51,
All the features of the SCXI 1126 card are in the .pdf documentation. You will find on the third page all the informations of the resoltuion of the card.
The resolution is about 8 bit.
You need to make the following operation to know your real resolution:
code width = Voltage range/(Amplification * 2^ resolution).
Here is the link of the document:
I would like to tell you that you posted your request in the English part of the forum. So you must make it in English or post your question in the french part if you have ones. Here is the link to the french part of the forum :
Jérémy M. | LinkedIn - Contact
Don't forget to give Kudos to good answers.
(6,548 Views)
