Signal Conditioning
SCXI 1530/1531 device support
I found confusing information about the support software of SCXI 1530. Now is this fully supported by both Traditioanl DAQ and DAQmx?
I found that some document said that "Traditional DAQ only when using an SCXI-1530, SCXI-1531, or SCXI-1540 device with accelerometer, linear-voltage differential transformer (LVDT), or rotary variable-differential transformer (RVDT) virtual channels, which are not supported by NI-DAQmx. " This should be outdated information?
(6,522 Views)
Accepted by topic author oly
Hi Oly,
To be sure it would help if I knew what document you are looking at. However looking at the Readme for DAQmx it seems like the SCXI-1530 is only supported for accelerometers and microphones, meaning the LVDT and RVDT task are not available.
NI-DAQmx 9.0.2 ReadMe
http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmx/9.0.2/readme.html
Hope that helps,
Scott M.
(6,511 Views)
Thank you..I guess what you mentioned is the updated information....
(6,507 Views)
