Signal Conditioning
SCXI-1600
Dear Mike Watts
Thank you for your continuous support and help.
Would you please help me to convert data record file from .lvm to .xlsx. Please find the two files attached herewith.
Regards
Palash Bhomwik
Message 11 of 14
(3,121 Views)
Hi Palash,
The .lvm files that you attached are already capable of opening with Microsoft Excel. The data is stored in a tab-delimited format, which allows Microsoft Excel to easily open and display the data to you. You may have to right-click on the file and choose to "Open With..." and select Microsoft Excel manually. Or, you can right-click on the file and select properties, which will allow you change the default program for opening files of type .lvm.
Also, as I mentioned in my previous post, you can choose to log the data directly to "Microsoft Excel (.xlsx)" in the "Write to Measurement File" VI configuration window. This will store the data directly to .xlsx format, instead of .lvm.
I hope this information helps!
Mike Watts
Product Manager - Modular Instruments
Message 12 of 14
(3,115 Views)
Dear Mike Watts
Thank you for your support and co-operation. For my purpose I want to record data when I need. But I am facing problem for this program that if I ON the Data Acquisition it log data after every certain eteration. Otherwise I have to turn-off the program. Can you guide me to log data in MS excel semilar to the attached MS Excel File: "Data Record Format" in a same file.
Yours Truly
Palash Kumar Bhowmik
Message 13 of 14
(3,101 Views)
Hi Palash,
Unfortunately, I do not think that I understand your explanation. Let me explain what I understood and maybe you can confirm or clarify my current understanding.
First, you run your VI with the "Write to Measurement File" Express VI disabled and then while the acquisition is running you press the Boolean control that enables the "Write to Measurement File" Express VI. The VI then acquires the data and logs the data to the Microsoft Excel file every loop iteration. If you press the same Boolean control again, are you saying that the VI still logs data to the file until you manually stop the VI?
Any clarification that you could provide would be very helpful. Also, if you have made any significant changes to your code, it would be helpful if you post a new copy of your VI.
Thanks!
Mike Watts
Message 14 of 14
(3,096 Views)
