Signal Conditioning
SCXI modules not auto detected
Hi Brooks,
I finally got a chassis to work. I have successfully auto-detected all (or no) modules using an SCXI-1600. I have done it on two different versions of NI-DAQmx: 8.7.1f2 and 8.7.2f1. If the customer is able to upgrade the driver version, I would try that. Let me know how that goes.
Mark E.
Precision DC Product Support Engineer
Message 11 of 12
(4,014 Views)
I have a SCXI-1000 Chassis with SCXI-1520 module and SCXI-1314 terminal. I am facing the same issue of module not auto-detected. The problem just started after inserting a similar module in the second slot.
I would also like to mention that the 2nd module had also the same problem with the 2nd similar chassis. Previously everything was working fine.
Please suggest a solution.
Message 12 of 12
(814 Views)
