Signal Conditioning
SCXI reading becomes unstable
Iam trying to measure a battery voltage(1.5 V)using
SCXI 1520 module.Intially it works fine.After some time the reading starts fluctuating.What can be the reason???
thanks in advance
(3,111 Views)
Capsys,
Fluctuating readings can happen for a variety of reasons. Check your signal connections: use short, shielded wires where possible to avoid noise. Also, make sure that your signals are properly grounded.
About how long does it take for the signal to start fluctuating? How large are the fluctuations. What is your end application? Generally, the 1520 module was made for strain gauges and other force measurements.
Have a great day!
(3,111 Views)
