Signal Conditioning
SMU 4140 current pulse question
Hello everyone,
I am seeking any advice or help on how to maintain stable a current pulse when its frequency is increased.
The equipment:
Chassis PXIe1078
Controller PXIe 8115
SMU: PXIe 4140 (4 channels)
The problem: I am correctly generating a 7mA - 14mA current pulse up to 20Hz but when I increase the frequency to for example 100Hz, the current signal attenuates to a 10mA - 12mA pulse, and if I keep increasing the frequency the signal becomes a complete mess.
Questions: How can I manage to stabilize the current pulse to higher frequencies without signal attenuation? Am I following a correct programming strategy from the point of view of the VI's that I am using? or should I use the "Current Pulse VI" of the DC power palette for example?
The VI: please find attached the VI that generates the current pulse. Try increasing the frequency (by reducing the time parameters in the "Delay" array)
Thanks for your kind help,
Cesar
(5,955 Views)
I can't open your vi, but a more general question:
What are you driving?
If you load is inductive you probably can't increase your current as fast as you want 😉
Greetings from Germany
Henrik
LV since v3.1
(5,928 Views)
Danke fuer deine Antowrt Henrik, (my German is terrible...)
The current is passing through a 1kOhm resistor that cannot be changed to a lower value. I've checked the SMU 4140 module specs and the voltage range is -10V to 10V and thats low considering the fixed resitor value.
I might be wrong, but I think I cannot achieve my goal with this SMU module.
Still, further ideas or advices are greatly appreciated.
Greetings from Mexico,
Cesar
(5,919 Views)
Ohm's Law: 10 V/1000 ohms = 10 mA. Therefore you cannot get 14 mA.
Lynn
(5,916 Views)
Indeed Lynn.
Thank you.
Cesar
(5,914 Views)
