Signal Conditioning
Setting up SCXI-1102 for a RTD
I have a SCXI-1102 and 100 OHM platinum RTDs.
They are conncted to a drive, if the drive is off, they read the correct temperature but when the drive is enabled the values jump about and are not constant.
I was just wondering if there is something wrong with the setup or could it be some kind of noise.
 See attachement for setup.
(4,012 Views)
Try a samplerate >300Hz and mean the values of one second ...
Have a look at one RTD signal with the highest possible samplerate, you migth find that there is a lot of power line noise  (and higher frequencies if a electronic converter is used)
Greetings from Germany
Henrik
LV since v3.1
(4,009 Views)
Henrik,
Thanks for the prompt reply.
I am sampling at 1000 samples a second, so I don't think it is that butI have found some more information:
Looking through the documentation of the SCXI-1102 it tells me that I also need a SCXI-1581.
Am I correct or do you know different.
TimS
(3,915 Views)
