Signal Conditioning
Strain gauge on AI(X+8)on SCC-SG24 doesnt work. Strain gauge on AI(x) works.
I have two full bridge, 350 ohm strain gauges that I want to log with a SCC-SG24 module. I am using a SC-2345 DAQ Device. WHen I wire the two strain gauges up to the SCC-SG24 module, only the strain gauge that is hooked up to the AI(X)+ and AI(X)- screw terminals(5 and 6) work. I can only read noise from the AI(X+8)+ and - terminals.
(3,370 Views)
Hello Kyle34,
You can check the connection diagram in the under the section titled connecting strain gauge input signals.
(3,363 Views)
Sorry, I included a link that did not show. The manual in PDF is located at http://www.ni.com/pdf/manuals/371073b.pdf
(3,361 Views)
