Signal Conditioning
Suggestions for long range LTE coverage supported antenna
Dear community,
I would like to know about any good quality antenna that can support long range communication compatible with USRP B200 mini. We have implemented the LTE setup using USRP B200 mini and initially tested the setup using a VERT 900, which can cover very few metres only.We need few antenna suggestions which can support around 100 m while enB running on LTE band 7, FDD mode and using 25 and 50 prb.Any power amplifier suggestion can be beneficial also, the target coverage area is around half of km.
I will highly appreciate your kind help. Thank you!
Warm Regards.
Message 1 of 1
(1,867 Views)
