Signal Conditioning
System hangs up on plugging the USB cable from SCXI1600 into my PC
Hello there,
My PC hung up twice during installation on plugging the USB cable from SCXI1600 into my PC.  I have installed Labview 7.1
followed by NI-DAQmx 7.4 drivers.  I then plug in the cable into one of the USB ports and then switch the power on on the chassis,
SCXI-1000.  My PC immediately goes into safe mode switches off and turns back on.  I do not know why this has happened.  It has worked
fine prior to this.
(3,575 Views)
Morning!
I figured out why my system was switching to safe mode and shutting the moment I plugged in the USB cable from my SCXI-1600.  That was the instruction coming in from Norton Anti-Virus which saw the power and data coming through the USB as a serious intrusion into the system and automatically shuts down even without asking me.  I now need to know how to change the setting on the Anti-Virus to recognise SCXI as a client on my computer.
Thank you to anyone thinking about this prob.
Cheers.
(3,570 Views)
Carnot:
Though I don't have a solution for you, I would like to note that was a very good and interesting find. Have you tried plugging in with Norton disabled as a sanity check? I wonder if Windows firewall (XP?) would also percieve this as a threat too.
(3,566 Views)
The Norton Anti-Virus isn't the real prob after all.  When I turned it off in the beginning it kinda seemed to have solved the prob but not subsequently.  I had to upgrade my BIOS and reinstall including the Driver for SCXI-1600 excusively when Windows asks when you first plug in after all the s/w installation.  Now my sys working normally as it should.  Cheerios.
(3,545 Views)
