Signal Conditioning
TC-2095
i am using 6034E along with two SCXI-1102 and two TC-2095.Both the module were working fine till one module
started reading 30 deg celcius at room temperature where as the actual room temperature was 24 deg celcius. The second module is reading correctly ie.24 deg celcius.What could be the problem? Is the CJC for the module has gone bad?
(4,038 Views)
Vinod;
Try to swap the modules of their respectively slots to see if the problem might be at one of the slots. If the same module shows the same behavior after you do that, the module is defective and need to be repaired.
Hope this helps.
Filipe A.
(4,037 Views)
