Signal Conditioning
Temp. measurement stopped working when SCC modules were instaled
I'm using a SCC 68 with a PCI 6221 data aquisition card to measure temperature with Labview.
When we srtarted the data aquisition, we did not use any SCC modules, but the VI worked fine.
After we got 2 NI SCC TC 02 modules for thermocouple input and after they were installed, the temperature measurement the VI stopped working. Both modules wereinstald in the DAQ assistant.
The signal that is shown now in the VI does not change even if I increase the temperature. When I unplugg the SCC TC 02 modules and connect the thermocouple directly to the SCC 68 the temperature measurement works fine.
I would really appreciate if somebody could help me with that.
I have the suspicion that I need to change the VI so it can measure temperature with the SCC modules.
(6,024 Views)
Thank you for using NI support.  Are you able to see the SCC module in Measurement and Automation Explorer?  Also, are you using one of the example VI's or is this a VI that you created?  Lastly, what inputs are you using on the SCC module?
(6,015 Views)
