Signal Conditioning
The connecting of 68-PCB
We can connect wires to the PP-68 PCB, but the connecting is not as safe as soldering. I am now testing the voltage from screws which are soldering to the definite lines, and i don't know whether the noise is coupled into the circuit by the other screws from the space(just like small antennae). I have a 68-POS right angle PWB mounting, but is hard to test directly from the pins(too near between the two pins). How can i verify the coupling effect of the connecting screws?
(3,514 Views)
Tomas,
Whenever I need to measure things in tight spaces I turn to my special scope probe tips, with them I can access those remote places and take measurements.
Just by doing a search in google you'll find probe kits like this one:
http://www.probemaster.com/german/page1.html
I use a similar kit to probe ICs and tight connectors. With them you'll be able to use the Scope to verify the noise.
good luck
eeguy
(3,514 Views)
Tomas,
At some level every conductive thing is coupled and is an antenna. But I doubt the screws of the SCB-68 are a significant problem.
As we have discussed before, I am doing DAQ in a noisy environment as you are. I have, by the process of elimination, demonstrated that my noise is radiated by my motor drive. Where exactly it is coupled to my system is not easy to find. I solved my problem by other means than shileding.
I don't think think anyone can answer the question you have asked regarding the screws. I think you should look elsewhere for a solution. For "most" applications the SCB-68 and the screw terminals work very well.
Again, I recommend the literature on Field Wiring and the Keithly and other books I described prev
iously.
Sorry and good luck,
mike
(3,514 Views)
