Signal Conditioning
Thermocouple output fed into two devices
I'll research on my own, but thought I'd post here in case anyone has had similar needs/solutions.
We have an extruder that we'd like to monitor and log data on. The majority of the signals are J and K type thermocouples that are fed into PID temperature controls. Unfortunately the PID controllers do not have retransmitter analog ouputs to scale the readings into V or mA. That would have been very convenient to interface to the appropriate DAQ hardware.
Thus, is it possible to connect a thermocouple input based DAQ to the same thermocouple inputs to on the PID controllers without affecting the signal? One thermocuple feeding two inputs- one to the PID, the other to the DAQ. I do not have the input specs yet for the PID controllers, presume the are >1Mohm. I would be using the appropriate thermocuple wire type as needed.
-AK2DM
(7,433 Views)
Once I saw a box to do it. It was custom made (with some nice OPs and lots of thoughts on how to avoid parasitic thermo emf)  to deal with µ-Volts provided by the TCs (and adds only about 2K additional error...)
However the only correct way I can think of, is to use a TC conditioner with CJ and an 'regular' output (20mA/X-Volt) that is capable to feed two inputs. Most controls can be configured to read theses standard outputs instead of a TC.
Greetings from Germany
Henrik
LV since v3.1
(7,411 Views)
Henrik:
Thanks for the advice, your sentiements are pretty much echoed in Omega's technical sections. Bummer, looks like retransmitters or 4-20mA converters are in store.
-AK2DM
(7,391 Views)
I have seen this done many times, without ill effect.  Just piggyback them together and you should be OK as long as the inputs are meant to take in thermocouples.
(7,367 Views)
I have also seen piggybacked connections used successfully.  With that said, these applications could tolerate error of ±20°F  -- You ARE introducing error in the signal.
(7,355 Views)
