Signal Conditioning
Time-frequency analysis of vibrational signals
Hello to everyone,
first of all  I'm a beginner of the signal's analysis and I hope someone can help me.
I'm trying to perform the time-frequency analysis of some vibration signals, acquired on a internal combustion engine. In particular I must do the tfa of a vibrational signal corresponding to one thermodynamic cycle of the engine; my Lb version is 2012.
In order to do this I'm using the advanced signal processing toolkit, in particular the "tfa stft spectogram" and I have attached in this message the simple VI I created. My issue is that in the intensity chart I should see frequencies about kHz, instead in my VI i see at max 25Hz.
Can someone help me in telling me in what I'm wrong?
(6,868 Views)
Have you provided the correct sample rate to the spectrogram vi?
Load some meaningful data and then rigth click on the XY Graph -> Data operations-> Make current values default
Save the vi and post it again. Or post a datafile too 😉
Greetings from Germany
Henrik
LV since v3.1
(6,851 Views)
Hi Henrik,
thanks for the answer and the help.
Yes I did,  if you mean the sample rate on the little block "tfa stft spectogram". However I followed your suggest but nothing's changed.
I attached one example of the vibrational signal of one thermodynamic cycle as you requested. Have you any other ideas?
(6,844 Views)
Almost 😉
Just play with the parameter (and read some basics to understand what you are doing)
Henrik
LV since v3.1
(6,826 Views)
and the vi
Henrik
LV since v3.1
(6,821 Views)
Yes, that's perfect!
Thanks very much Henrik, you've created a great event driven VI!
Actually I'm going to start read the "time frequency analysis tools- user manual" by NI; do you think is it a good guide?
(6,814 Views)
Hello to everyone,
is there anyone that could tell me why when i try to plot the TFA  2D rappresentation (time vs frequency) in a 3D surface the values on the  three axis do not match with those of the spectrogram?
(6,552 Views)
