Signal Conditioning
Trouble to specify the sensors for SCXI-1530
I am having trouble specifying the microphone and accelerometer IEPE, supported by the SCXI-1530 module.
Which brands and models of microphones and accelerometers used for this module?
(6,110 Views)
Hi guilhermemk
SCXI-1530 module specification can be found in the link below:
http://www.ni.com/pdf/manuals/322642a.pdf
The sensor must follow these specs to work correctly with this module.
You can found companies that work with this sensors in search web sites, like google
Regards
André Bassoli Napoleão
Application Engineering
p.s.: If you want, you can write in portuguese in this forum
(6,078 Views)
