Signal Conditioning
USB 6015 chassis size
Is there a USB 6015 chassis available in black that is the same width and length as a 2345 SCC chassis? Thank You!
(3,301 Views)
Let's see...the dimensions of the SC 2345 are 24.1 cm × 26.2 cm × 3.937 cm (9.5 in. × 10.3 in. × 1.55 in.)
1. We have the DAQPad 6015/6016 that has dimensions of 17.60 by 14.85 by 3.08 cm (8.00 by 6.75 by 1.40 in.)
2. We also have the DAQPad-6020E that has three form factors:
a. Half-size box Desktop use dimensions of 5.8 in x 8.4 in x 1.5 in.
I/O Connector: 68-pin SCSI II Male
b. Full-size box(12.1 in x 10 in x 1.7 in) Rack-mountable, stackable.
c. Full-size box(12.1 in x 10 in x 1.7 in) Rack-mountable, stackable.
I/O Connector: BNC and removable screw terminals
Please let me know if you are interested in any of these devices so that I can put you in contact with an ISR.
LA
(3,292 Views)
