Signal Conditioning
Unable to add AT-MIO-16L-9 in NI-DAQ Configuration Utility
I'm trying to get my computer to recognize my AT-MIO-16L-9 board.  In the configuration utility, I try to "Add" a "DAQ Device".  The wizard popped up and asks for things such as the I/O Range and DMA, and I filled those values in.  However, when I hit the "Next" button, nothing happens.  No error, no closing of windows--just no response.
(4,195 Views)
I hope you have installed the compatible device drivers for your AT-MIO-16L-9 board : 'Traditional NI-DAQ (Legacy) Version 6.1 for Windows 95/98/NT'
If not, You can download it form here
(4,195 Views)
Sorry, I had entered system params from the list before posting, so I thought they'd show up here.  I'm running Windows 2000, and NI-DAQ configuration utility version 6.1 (that has the drivers in it, yes?).  Thanks
(4,182 Views)
Hi nathan,
According to this link that shows compatibility of various cards with different OS, your card is not supported on WIndows 2000 and thus it will not work. You need to use either Windows NT or Windows 95 to run your AT board.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(4,161 Views)
