Signal Conditioning
Using 4 LP in SCC-2345 for 8 channels -> PCI 6143?
I just purchased a PCI-6143 with 8 differntial channels.  I would like to use the 2 channels on each of my 3 LP04 and 1 LP03 Butterworths in my SCC 2345 to filter my voltage analog input signals to the 8 differential inputs on the card.  Is there a way to define which channels on the SCC should link to the 6143 inputs?  For example using aio8 from the SCC as an input to aio4 on the 6143.
(3,585 Views)
Hi Annatto,
The pins on your DAQ card route to different (but specific) modules on the SCC-2345 chassis. The routing is labeled on the chassis. For example, if you put your LP03 module in slot 1, then this will be routed to the differential channel ai0. This is hardwired so you cannot change it in software. Refer to Measurement and Automation Explorer (MAX) for how each channel on your DAQ card will route to the SCC-2345.
Hope this helps!
Garrett H
(3,576 Views)
