Signal Conditioning
We see the SCXI 1166 relays sticking closed often. Several attemps to toggle
(6,602 Views)
What are you controlling with the relay outputs?
(6,596 Views)
Centerbolt:
Read the comment posted below the 1st video 🙂
http://forums.lavag.org/print.html&client=printer&f=47&t=7605
-AK2DM
(6,582 Views)
Are these consistently the same relays?  Do all relays exhibit this behavior?  If this is only a few relays you can follow the relay replacement guide within NI Switches Help.
Sincerely,
Jason Daming
http://www.ni.com/support
(6,566 Views)
