Signal Conditioning
What's the best tools (hardware and software) to measure the sound of an aircraft?
We are trying to measure the sound of an aircraft by driving a microphone-equiped van along with the aircraft on the run way. We'll then store the data on datasocket server so that we can display the data in real-time on the web. My question is what's the best tool (hardware and software) for this application? Thanks.
(5,216 Views)
I agree with Raecine who posted an answer to the same question in the RealTime catagory. The best hardware solution would be one the the DSA Boards. If you have the option to use a PXI setup I would recommend the NI 4472 which has 8 simultaneously sampled channels with 24-bits of resolution
(5,216 Views)
