Signal Conditioning
What should be the extra circuitry for this??
I am an undergraduate student working on project for measurement of automotive relay parameter measurement using LabVIEW. The parameters to be measured are:
1)Operating time 2)Release time 3)Pull up voltage 4)Drop off voltage 5)Coil Resistance 6)mV drop across contacts.
For this, I am using NI PXI 1052, SCXI 1125 and SCXI 1313 attenuator with LabVIEW.The relay to be tested is of 12V-15A.
I want to know what extra electronic circuitry will be required to measure the above parameters?
(5,477 Views)
Duplicate post !
(5,475 Views)
