Signal Conditioning
Which module of CompactRIO can be used to measure strain gage
I wonder which module of compactrio can be used to measure strain gage. or should i use the analog input module to measure the value and use the analog output module to excite the bridge?
(3,773 Views)
You are correct that you can use any of the analog input modules to take measurements, and use analog output modules for bridge excitation. You might also need to add other external components for bridge completion, depending on your sensor.
Vineet A.
(3,751 Views)
Thank you very much
(3,739 Views)
