Signal Conditioning
Whould you please confirm on this SCXI selection ?!
Greetings everybody,
For  all the SCXI experts, I'm going to order an SCXI system, But I want to be sure about two specific items (the Cable assembly and the Shielded Cable)
My application requires an SCXI-1100 module.
The SCXI system will be connected to an M series PCI - DAQ card, and I want to use some of the AO, DIO points in this card.
Here are my choices:
SCXI - 1000 "chassis chassis"
SCXI - 1100 "32 AI module"
SCXI - 1300 "Terminal block for the 1100"
SCXI - 1180 "Feed Through module"
SCXI - 1302 "Terminal block for the 1180"
SCXI - 1349 "Assembly for connection with the PCI card" [182671-01]
NI PCI - 6221 "This is my M Series DAQ card" [779066-01]
SHC68-68-EPM (2M) [192061-02]
The Advisor works well so you can't forget an item, but the problem is that it doesn't tell about all the options avialble (for example: All PCI daq cards) and another temporary problem: It's n't working now!
My questions:
1- I want to be sure about the compatibility of the last three items (Number of Pins .. etc)
2- Do I have to specify any other detail for the last three items (I'm really afraid of the number of Pens!)
Thanks to you all in advance
Message Edited by Ayman_Metwally on 03-16-2006 05:08 AM
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
(3,431 Views)
Hi Ayman,
Those last 3 choices will work perfectly. You should have no problem with that setup.
Hope this answers all your questions
Regards
JamesC
NIUK and Ireland
(3,423 Views)
Thanks alot James,
I appreciate your answers.
Automation Engineer
Egypt - Cairo
(3,409 Views)
