Signal Conditioning
Why do i need either a SCC or SCXI device to interface between my instrumentation and my E-series DAQ board?
Do i need signal conditioning or can i simply connect the instrumentation to the DAQ board?
(3,725 Views)
Hello;
That will depend on what type of signal you transducers are delivering.
If the sensors give back a noise signal or maybe a low amplitude signal, you might consider the idea of conditioning the signals.
That will depend also, on how accurate you want the signal to be read.
Hope this helps.
Filipe
(3,725 Views)
