Signal Conditioning
Won't recognize chassis, checked fuses and reinstalled everything
I've tried everythig I can think of. My SCXI chassis was working this Am, I went over to another computer to see if i could figure out why my 1160 board was giving me an error ( I think it was 3044??) I could not get my other chassis to work, and when I went to reinstall the original chassis it now will not recognize it. We did have a power outage 4 days ago, but.....? Any ideas or stuff I should check. I've swapped cables and connnectors and all that. What really is wierd is that both chassis are not being recognized on either of two different computers.
(3,952 Views)
Hi Blest1,
I have a few follow-up questions about your setup:
  1. Is the SCXI-1160 the only module that is not being recognized?  If so, what other modules are you using?  Is it in the Measurement & Automation Explorer that the modules are not recognized?
  2. Which SCXI module is the communicating module?  In other words, which module is cabled to your data acquisition card?
  3. What data acquisition card are you using to cable into your SCXI chassis?
If you can fill us in with some more details, we'll do our best to help you diagnose this problem.  Thanks!
Thaison V
(3,941 Views)
Thanks, but I found the problem. Sophamoric misstake. The 1121 first in line was not communicating with th M10-16E board. Sorry to bother y'all. It's one of the first things I should have checked, but I was in a hurry...and...I was sure of ....and. Thanks to Zack Olson in Orange County Cal. for getting my head sraightened out.
Blest1s@aol.com
mtimberlake@nov.com
(3,932 Views)
