Signal Conditioning
accelerometer data acquisition
I´m with some doubts in my accelerometer data acquisition and I´d like to share with the community
I'm using two PCB single axis accels and NI cDAQ-9178 with one NI-9234 module. Before acquiring some data, I have checked my accels with my handheld shaker and it worked good.
When I start acquiring, most of my data looks fine, but in some instances I am getting some strange data. I have cutted and attached some parts that it happened.
I cannot understand where this distortion is coming from - I have checked connections and cables, but they´re good.
Does anybody know what is going on? Does it really happens with my accels?
(6,835 Views)
Please Post a .png picture of it.
Posting the data is Perfect for analyses but currently I'm with this mobile stuff
Greetings from Germany
Henrik
LV since v3.1
(6,763 Views)
Hello Henrik,
Thanks for the insterested. Please find attached the picture.
regards,
(6,690 Views)
If you have short loose contacts, thats the signal you get with IEPEs.
Henrik
LV since v3.1
(6,669 Views)
Hello Henrik,
I´ve checked my contacts and everything looks good.
I´ve done one test that during an acquisition, I´ve shaked the cables close to my data acquisition but nothing happens.
Another test that I´ve done was simulate a hit. I´ve got one plate and installed my accelerometer, them I hit it twice with two different strengh. I´ve repeated the process and the results were all the same - when I hit it harder the same phenomenom happens in my signal.
My rack is cdaq-9178 with one module NI9234. Can you simulate it?
(6,572 Views)
Sorry for the late reply,
I still vote for loose contacts, but there is an other mechanism that migth cause that signal.
Do you have any switched power controllers nearby?  (Motor controller, not so well shielded/filtered class D amplifier?)
Henrik
LV since v3.1
(6,490 Views)
If not the connection issue, another possibility is that the IEPE accel is overloaded. What is the range (or model #) of the PCB accel?
(6,472 Views)
