Signal Conditioning
acquire more channel with labview 7.1 and scxi1200
Good morning all,
i have a problem to acquire more channel (4 analogic channells)with a SCXI1200 on labview7.1 and Win2000.
i try to acquire just one AI and it's all ok but when i add a channell in my VI i can't acquire none (i've tried with easy and complex sub VI, the results are the same). the test on single AI are ok!!
Thanks in advance.
PS:i'm sorry for my english.
(3,262 Views)
When you say you are not able to acquire more than 1 AI channel with LabVIEW, are you getting any error indication in your VI, any error code or anything?
It would be interesting to know if you receive any error.
Also, what happens if you try to acquire 2 or more channels from the test panels in MAX?
What is the sampling rate you are specifying?
AlessioD
(3,262 Views)
I've not any error, i haven't try to acquire more chennells with max.... i'll do it!!!!!
i try to acquire at 200Hz!!!!
thank you....
(3,262 Views)
