Signal Conditioning
anyone have a good pH meter vi?
(5,449 Views)
A little confused on this one. If you are measuring pH the VI will depend on what type of tranducer and DAQ card you are using to measure pH Level. Most pH meters simply have a digital display with the pH level and maybe some other information. The great thing about LabVIEW is that you can customize how you want the display to look, and what information is posted on the display. You can change colors, fonts and lots of other features.
It may be easier for someone to post an example for you if they know what hardware you using to measure the pH. This will insure that you will get an example that will work with your setup.
(5,449 Views)
 i am also doing daq on ph..im using advantech usb4716 as the daq, rosmount high temp pH sensors and i need to switch on pumps automatically at certain range of pH using labview 8.5..can anyone help me on the programing and wiring..mail at escude_camaraderie@yahoo.com..
(4,673 Views)
Just a warning - pH probes generally have VERY high output impedance ~600 megaOhms (yes, mega).  Make sure your Daq can handle that.  Your pH probe may already have some signal conditioning that would make it easier.
(4,572 Views)
