Signal Conditioning
cDAQ-9171 ground screw spec
I'm missing a few of those ground screw for the cDAQ-9171. I suppose this ground screw follows some US standard—but which one exactly?
Annoyingly, the larger cDAQs like the cDAQ-9174 and cDAQ-9178 use a bigger screw. 😕
(239 Views)
Hi Jossy,
The ground screw used on the NI cDAQ-9171 is likely a slotted #6-32 UNC screw, which conforms to a standard U.S. thread type commonly used for grounding.
If you need a replacement, a #6-32 UNC slotted screw, approximately 1/4 inch (6–7 mm) long, should be suitable.
Best regards
(134 Views)
thx :)!
(124 Views)
