Signal Conditioning
can i use these SCXI modul with terminal blocks ?
i am trying to select SCXI-1520,SCXI-1540,SCXI-1102 as the signal modules for my DAQ SYSTEM,can i use them without terminal blocks such SCXI-1315 in SCXI-1000 chassis? if i must use them,which configure can meet my requierments with low price while keeping high precision?
(3,190 Views)
In any case, you'll have to have something that connects to the module's front connector. Usually each module's user manual will mention compatible terminal blocks. The right terminal block depends on the signal you are trying to measure. For the highest precision, you really might want one of the recommended terminal blocks. However, we do offer the Keywords Search: 1330 custom connector option as well.
-Russell
Message Edited by Molly K on 02-19-2005 12:08 AM
(3,191 Views)
