Signal Conditioning
can't select Properties for SCXI module
When I go to Measurement and Automation Explorer and go to Devices and Interfaces, I can't select Properties for the SCXI module SCXI-1531. I can for my chassis, SCXI-1000. I can for my DAQ card, PCI-6259. The problem is I can't go in and configure the 1531 module.
(3,105 Views)
Dave,
Greetings!
For DAQmx, you should be able to setup all of your channel settings for the SCXI-1531 by creating a DAQmx Task. Previously, in Traditional DAQ, this was done by selecting Properties.
Hope this helps,
Anuj D.
(3,105 Views)
