Signal Conditioning
comparison between 6210 & 6215
need to know the differences between usb-6210 & usb-6215.
(6,562 Views)
Hi mfaizal,
can you be a bit more precise? Which response do you expect?
https://www.ni.com/en-us/support/model.usb-6210.html
https://www.ni.com/en-us/support/model.usb-6215.html
The USB 6215 has two additional analog outputs.
Mike
(6,560 Views)
thanks...
If originally i'm using 6215, can i change to 6210. any configuration needed?
Hi Mike,
(6,542 Views)
Hi mfaizal,
if you don't need the analog outputs, then you can change to 6210. It should be easy, because both cards work with DAQmx.
Mike
(6,493 Views)
