Signal Conditioning
determinig the slot position of the module in SCXI
I want to the exact slot position of the scxi card.
Has any one have any program to auto detect it. i have tried without much sucess using SCXI_ModuleID_Read function. i have tried doing this using call LIbrary function. Can anyone help me ??
Suresh Thangappan
(3,053 Views)
Hi Suresh,
Sounds like you are using LabVIEW with the Traditional NI-DAQ driver. In that case, the easiest solution is to use the "Get SCXI Information.vi" in the "Calibration and Configuration" palette. Refer to the "Help" for explanations on the terminals.
I hope you can use this answer.
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,053 Views)
