Signal Conditioning
getting program to a SCXI box
I have a program that I have created that generates a square wave output signal.  The problem is that I do not know how to output this signal to my SCXI-1000 box with the SCXI-1325 module.  Would I use a visa output or is there an easier way to accomplish this task?  If I use a visa how do I find the SCXI box through a channel/task in or physical channel button?
(6,087 Views)
I am not sure exactly what module you are using (the SCXI-1325 is a terminal block for a module) but you can directly select the module and channel of the device when you are setting up your task.  For example, if you want to output an analog output signal, you would select the device and channel directly to the scxi chassis if it is configured.  I posted a screen shot of what your SCXI chassis in Measurement and Automation Explorer should look like and how to set it up.  In your program you will use the resource name you associated with your device.  You will select the SCXI module in the exact same way as you would select a DAQ card.  I also posted a screen shot in LabVIEW of what your SCXI chassis will look like.
Jordan F
(6,078 Views)
