Signal Conditioning
how do I add a SCXI-1160 to my system?
This falls into the 'had some extra parts, let's use them' category.
My current configuration is PCI-6221 into a SCXI-1001 Chassis with a 1349 Cable Adapter.  The only modules I have in this chassis right now are a 1102/b/c with a 1303 terminal block and a 1180 feedthrough with a 1302 terminal block.
I've come across a spare SCXI-1160 module with 1342 breakout connector.  I'd like to use this for some switching tasks rather than the analog outputs of my 6221 (need more channels than the card has, which is two).  This module came to me with no documentation or cabling so I'm unsure how to connect it to my current system.
If someone could point me in the right direction for the correct cable to purchase I'd appreciate it, and input on the connection setup as well.  Much thanks
Ralph
___________________________________________________________________
Still confused after 8 years.
(3,389 Views)
Hi Ralph,
You shouldn't need any extra cabling to be able to control or interface with your SCXI-1160 relay module.  The 1160 can be controlled from the PCI-6221 M-Series card (via the 1349 adapter), and the 1324 terminal block provides the interface for the relays.  Check out this tutorial for more information on connecting signals to the 1160.
Try installing the 1160, adding it to your SCXI chassis in MAX, and try switching with the Switch Soft Front Panel.  Let me know how this goes.
Have a great day!
Travis W
(3,374 Views)
