Signal Conditioning
how do i verify the filter setting set in SCXI 1102b module
How do i verfiy the filter setting set in SCXI 1102b module prorammatically per channel
Suresh Thangappan
(3,891 Views)
Hello Suresh,
Thank you for contacting National Instruments.
If you are using NI-DAQmx, you can use a channel property node to retrieve the cutoff frequency of your input filter. Please see the attached screen shot for details.
In Traditional DAQ, use the AI Parameter.vi located under NI Measurements >> Data Acquisition >> Analog Input >> Advanced Analog Input >> AI Parameter. See the screenshot below for details.
Let me know if you have any further questions.
Sincerely,
Sean C.
(3,884 Views)
This set up for hardware or software and how about the effect. can i filter against the 50HZ power noise?
(3,676 Views)
This is a duplicate post, guqunlin's question is also posted here.
Micaela N
(3,650 Views)
