Signal Conditioning
how does the pin of SCXI-1302 relate to E serious MIO board
I use PCI-MIO-16E-4 to control my scxi(scxi 1000+1100+1300+1302). Now I want to use the counter and +5V power of MIO board. How does the pins of SCXI 1302 (50 pins) relate to the pins of my MIO board(68 pins)?
(3,866 Views)
Dear Jack,
Please find attached a .zip file which I took from a Knowledge base article entitled "Cable Mapping for a 68 Pin Connector to a 50 Pin Connector" in here you will find a the pin-outs for a 68 pin connector and a 50 pin connector for the E-series boards. When you use the SCXI-1302 you are essentially converting the 68pins of the PCI-MIO-16E-4 to 50 pins, so follow the 50 pin connector diagram and you will see which connections you need to make.
Regards, Sally Tipper -NI.
(3,866 Views)
Jack;
To access the unused DAQ board lines from the SCXI chassis, you will need to have the SCXI-1180 module, which gives you access to all those lines from the SCXI chassis front panel.
Hope this helps.
Filipe
(3,866 Views)
Exactly what I required. Why isn't this easy to find in the NI manuals?
(3,866 Views)
