Signal Conditioning
how to use "if then..else..end if" in formula node
I want to use conditional expressions such as
if () then
statement
else
end if
in the formula node, but there were error messages "unassigned output". Anybody has an idea?
Lei Zhao
(4,052 Views)
Hi Lei,
The syntax for formula node would be
if (condition)
{statements to be performed if condition is true}
else
As a specific example you can copy and paste the following code into a formula node with one input x and two outputs y and z.
if (x<5)
y=4;
z=8;
else
y=8;
z=4;
You can also search on LabVIEW VI, Function and How-to help for more information on formula node in LabVIEW.
I hope it helps.
Ankita A.
(4,042 Views)
