Signal Conditioning
in the DSP, get/set the data of SCXI1162 through Multifunction E series board
I am integrating DSP board(cPCI) with your scxi1162, pxi-1052, pxi-6040e.
For the configuration of scxi-1162, the sbc will do that and DSP read the data
through pxi-6040e. Can I do this ?
Because you made the driver for pxi-6040e with scxi-1162 and I can not see the source code,
It is difficult to make my own code for reading data of scxi-1162. Even though I made
and test the code according to the manual of scxi-1162, I can not success.
If you give one or two source code(just using the port) in all of the libraries,
I can make my own code on the DSP board easily.
Best Regards
Dongkue Ho
(2,871 Views)
Hello Dongkue Ho,
Unfortunately, National Instruments does not provide any source code for its drivers.
For informtation concerning Register Level Programming with DSP, please see the NI Measurement Hardware Driver Development Kit (DDK) at http://sine.ni.com/nips/cds/view/p/lang/en/nid/11737 . This is the only support offered for RLP programming.
Sean C.
(2,859 Views)
