Signal Conditioning
looking for info to allow connection between a PC and E-series daq card to a SCXI rack inside a NEMA 12 encl.
were looking at an application where an SCXI rack will be installed on some equipment that will be used during different tests. the rack will be enclosed inside a NEMA 12, steel junction box for proctection. i want to build or buy a bulkhead connector to allow connection to a PC for data collection during the test.
if i had more info on the 68-pin connector (manuf., p/n, etc.) i could probably build my own. but before i do that i want to make sure that there hasn't something like that already on the market.
(2,896 Views)
Here is a KB that contains most of the information about NIs customer cables, part numbers and manufacturers.
http://digital.ni.com/public.nsf/websearch/8ECF4BAD615F18BC8625648400521E97?OpenDocument
My suggestion would be to take the SCXI 1349 and use it as a bulkhead connector. Then use a standard 50 pin ribbon cable to connect the 1349 to the SCXI module.
I hope this helps.
Joshua
(2,896 Views)
