Signal Conditioning
modifying the scale at a chosen frequency
hello,
i would like to center the frequency scale of my graph at a frequency that i chosed, but the scale is blocked between 0 to 125 khz and want to see it at 1420 Mhz, don't know if there is a problem with my program as i am new  with labview, thanks a lot for your help.
Here my diagram :
(4,935 Views)
Dop you see the red dot at your FFT vi? (feeding a num array to a wfrm input)
The sample frequency is now assumed to be 1
to get the correct frequency scale you need to provide the sample rate (as time dt)  in the wfrm cluster, or do some math and scale your graph 🙂
 and why do you have the feedback nodes in the wire?
Are you playing with RTLSDR?
Greetings from Germany
Henrik
LV since v3.1
(4,924 Views)
Hi Henrik,
If sample frequency was 1Hz, shouldn't the graph plot only values from 0 to 0.5Hz ? I agree that without dt the VI should lead to a sample frequency of 1Hz but it doesn't seem like it does. As the subject was posted on the French forum too, I tried to find an explanation but couldn't get any clue as of why it gives these results.
Any thought about that problem or did I miss something ?
Thanks in advance.
CLAMaxime -- Kudos are a great way to say thank you
(4,918 Views)
Hello sir,
thank you for your anwser, i am a student from france and i have a project with creating a rtlsdr system via labview to see the hydrogen ray  at 1420 Mhz.
I see the red point, but then i don't understand what i have to do, i am a beginner to LV so i don't understand where is the "wfrm cluster",  and how to do scale graph  using mathematics in LV.
Cordially
here is my program
(4,917 Views)
