Signal Conditioning
need to average real time data
I have a sensor that sends 1000 samples per second, The signal is very noisey. I would like a Vi that can read these samples from DAQ6009 and average them out (probably take 10 samples then average, then take next 10 and average and so on). I need to graph the averages and also I need to generate an on/off signal through the DAQ based on the results.
(5,565 Views)
I would advise starting off with the "Cont Acq&Graph Voltage-Int Clk.vi" example which can be found in the example finder under Hardware Input and Output > DAQmx > Analog Measurements > Voltage. Here you can experiment with acquiring your sensor data and graphing it. Once you are successfully acquiring this in the manner which you desire, you can begin to look at the post processing stage and subsequent output signals.
Kind Regards,
(5,547 Views)
