Signal Conditioning
ni 6323 Virtual TEDS for a UNIK 5000 Pressure Sensor
Hi all,
i have a  NI PCI-e 6323 boards and
i'd like to know if is there an available TEDS for a Unik 5000 pressure sensor from GE or if not how i can create a virtual TEDS and which benefits this action can have for my pressure measurement task.
Thanks in advance
MR
(6,097 Views)
Hi Mariano,
in the following you can find informations on how create and use virtual TEDS files:
How Do I Create a Virtual TEDS for My Transducer/Sensor?
How Do I Create a Virtual TEDS Task with the DAQ Assistant?
Here you can find some examples:
Creating Virtual TEDS
Reference Example for Reading and Writing Calibration Information to Virtual TEDS Files
I hope these informations will help you.
Kind regards.
CLA_Cup
NI ITALY
AE Dept.
(6,067 Views)
Hi Mariano,
(6,066 Views)
Hello Cla_Cup,
i premit i'm not using LabView 'cause we use .net library to interface with pci 6323, additionally the last two links you provide me are broken, browser reports page not found
(6,052 Views)
Also what reported at http://digital.ni.com/public.nsf/allkb/B0B0FFA7203ACC168625714300680CA0?OpenDocument
Solution:
Virtual TEDS files can be downloaded from NI’s Virtual TEDS Database. You should check this database first to see if any TEDS are available for your sensor.
the link for NI’s Virtual TEDS Database doesn't work (http://sine.ni.com/vteds/VirtualTEDS) and my browser is redirected to http://www.ni.com/products/i/
(6,051 Views)
Hi Mariano,
her there are working links:
Upgrading Your System for Virtual TEDS
IEEE 1451.4 Standard Overview
Hope these will help you.
Kind Regards
CLA_CUP
NI ITALY
AE Dept.
(6,046 Views)
Hi Cla_Cup, thanks for the answer.
The issue here is that i'm not using labview and the link is about
How can I create a Virtual TEDS for use with this sensor in Measurement & Automation Explorer (MAX) and LabVIEW?"
so i'm wondering if there is a tool to create TEDS virtual file 'cause i haven't found it in NI database.
Is it possible to take advantage of this technology using .NET coding? virtual TEDS file is intended to be loaded in MAX for the appropriate analog input of PCIe 6323 card?
Thanks in advance.
MR
(6,041 Views)
