Signal Conditioning
ni scope 5132
Hi, can I get measure with ni scope 5132 from the two channel in the same time, I tried to do that with labview, so one channel worked but the other doesn’t , can you help me thanks
(5,586 Views)
Hello
Thank you for bring this issue to the forums. Since your card is a USB-5132 it has 2 simultaneously sampled channels with 8-bit resolution and you will be able to measure a signal from both channels at once. Please open LabVIEW and open the example niScope EX Configured Acquisition. You can find this example in LabVIEW, go-to Help>Find Examples.. then search for "niScope EX Configured Acquisition." When you open this example make sure to choose the right resource name and, to select multiple channels write "0:1" in the Channel Name(s) control.
Let me know how this works out for you.
Thank you,
Vimal Fernandez
ELP Engineer
Applications Engineering
(5,567 Views)
